Madmapper & Enttec Open DMX USB
  • mupp17
    by mupp17 » Tue Apr 22, 2014 8:50 pm
    is it possible to connect Madmapper with the Enttec Open DMX USB?
    Or is it only possible with the Enttec DMX USB Pro?
    Thanks for your answer!
    Best regards,
    mupp17
  • cbultra
    Re: Madmapper & Enttec Open DMX USB
    by cbultra » Fri May 09, 2014 8:28 pm
    Both devices are fully compatible for sending and receiving.
  • rueangrith
    by rueangrith » Mon Nov 17, 2014 4:17 pm
    i just bought Enttec open DMX USB but in madmapper DMX output device is nothing. already install FTDI 2.2.18.
    by mad-matt » Wed Aug 22, 2018 10:03 am
    Enttec Open USB DMX is not actually supported (as of 3.5.1). It's not as reliable as Enttec Pro box and we don't want to make users life complicated. Since MadMapper 3.0 (if I remember well), MadMapper supports both FTDI drivers (Simple Serial-VCP & D2XX) so it should always work: whether you use the default macOS driver (VCP) or if you installed the D2XX driver, same for Windows (except I think the driver is not installed by default on the system)
  • MaartenEnnik
    by MaartenEnnik » Thu May 30, 2019 9:45 am
    Dear Mad-Matt,
    With the Enttec pro box you mean the Enttec DMX USB Pro Interface or the Enttec DMX USB Pro MK2 Inter­face?
    Thanks in advance
    by mad-matt » Thu May 30, 2019 11:06 am
    Both Enttec DMX USB Pro & Enttec DMX USB Pro MK2 are supported (Mk2 is compatible with Pro)
    Any Enttec Pro compatible USB DMX device is ok too (for instance DMX King eDMX2 Pro: https://dmxking.com/artnetsacn/edmx2-pro)
Users browsing this forum: No registered users and 72 guests
