ps3 Controller
  • 2lifetalent
    ps3 Controller
    by 2lifetalent » Wed May 07, 2014 2:42 am
    I am unable to figure out how to use a PS3 controller with 1.6. I use the control list, add a command, but nothing seems to be functioning. Is there a plug-in I need to get it to work? I realize I'm a little behind as this has been in Beta for a while, but any help would be greatly appreciated. Thank you in advance.
    Re: ps3 Controller
    by franz » Wed May 07, 2014 10:00 am
    plug your ps3 controller to your computer with a usb cable first, press the Home button to activate the controller, then go to the control list and assign a control (like joypad X to a surface X position for instance).
    Note that if your PS3 is lying around, the controller won't connect to your computer, but will "prefer" the console.
