Color not working with HAP codec.
  • freespirit
    by freespirit » Wed May 07, 2014 11:56 am
    I just started trying the HAP codec and the new Modul8. But when I use a HAP encoded file, non of the color controls seem to work, neither Auto Color nor the normal controls. I loaded the original H.264 file and with that the colors work perfectly. Any ideas?
    edit: tried some more. normal HAP works HAP Q is the problem. Also tried with an official Apple GPU insteas of my GTX570, as that causes some issues with some apps. But this time that didn't change anything.
    david
    Re: Color not working with HAP codec.
    by david » Tue May 20, 2014 5:10 pm
    Hello freespirit,
    we corrected some HAP related bugs :
    - additive color/autocolor not working with HAP Q encoded medias
    - fade/crossfade/alpha not working with HAP Q encoded medias
    - Transformer|Patch not working with HAP medias
    If you need a working version before we release 2.8.1, please contact support [at] garagecube [dot] com
    Regards.
  • samulj
    by samulj » Fri Oct 24, 2014 8:16 pm
    Any plans for an update?
    I would like to try the Hap Q, but the fader bug prevents me from doing it in my sets.
    david
    by david » Sat Oct 25, 2014 6:44 pm
    Hello samulj,
    samulj wrote:Any plans for an update?
    Modul8 2.9 alpha should be out in the next few days. It will correct the HAP Q bug.
    Regards
Users browsing this forum: No registered users and 65 guests
