Mapping your own screen.
  • franzalba
    by franzalba » Thu May 08, 2014 9:18 pm
    Hi everybody, Today I've been trying to map my own screen. I don't know if there are a way to do that with MadMapper or Modul8. If someone kwno a way to do that it would be great because I don't really have a result. Suggestions?
    Thanks! :evil:
  • al_baum
    Re: Mapping your own screen.
    by al_baum » Sat May 10, 2014 4:30 pm
    If I understand well, you would like to map the main screen of your computer.
    I am not so sure on how you can do this, since if you are using Madmapper on your screen, this is what you will be outputting. Maybe I do not get exactly what you mean.
    Anyhow, if you want to map a part of your desktop, you could try syphon virtual screen, which creates an extension of your desktop and allows you to 'syphon' it. Easy to use and seems to work well
    http://andreacremaschi.github.io/Syphon-virtual-screen/
    Best
    ALain
