OSC to control perspective transform
  • benoitsimon
    by benoitsimon » Tue May 13, 2014 1:22 am
    Hi Folks,
    After a deep review of the forum topics, I haven't find a way to control the XY Pad of the Perspective Transform module via OSC.
    I know that it could be mapped via MIDI but it's not so handy and probably less precise than OSC.
    Can someone help me?
    Thanks in advance.
    Benoit.
    Re: OSC to control perspective transform
    by sigmasix » Tue May 13, 2014 8:13 pm
    You won't be able to do that. OSC is not natively implemented into modul8… but you can do that very easily with madmapper now! give it a try :)
  • benoitsimon
    by benoitsimon » Tue May 13, 2014 10:29 pm
    Thanks Sigmasix,
    I already own a madmapper license but it's for another type of job. Modul8 would be used by a lighting designer to use the video as classical (but sharp) profile fixtures. He's using Dlight software to manage the traditional light and I give him the ability to control modul8 with OSC as if it were classical channels.
    I don't want him to add another layer of software...
    Many thanks. So, I will convert OSC signal to MIDI or use VDMX.
    Benoit.
  • benoitsimon
    by benoitsimon » Mon May 19, 2014 8:43 pm
    Just another quick question: the MIDI mapping for that module is designed to be set on the selected layer. Is there a possibility to duplicate it and apply two differents mappings (one for the layer 1 and one for the layer 2)?
    Thanks in advance.
    Benoit.
