DMX control in 1.6.1
  • unknownuser23
    by unknownuser23 » Tue May 20, 2014 2:36 am
    After updating to 1.6.1 my DMX setup is not working with my Enttec Open DMX Ethernet (ODE)
    It worked fine with the previous version but not with the new one..
    Is this not supported yet or did I do something wrong in my setup?
    Im testing with cuepix (http://www.elationlighting.com/ProductD ... ategory=34)
    a simple 1x5 led strip with 15 channel dmx control.
    I can literally switch between the old version and the new one and get it working..
    Any help?
    Re: DMX control in 1.6.1
    by franz » Tue May 20, 2014 6:23 pm
    MMM... can you get in touch with the support ?
    Basically we added Unicast support with 1.6.x, so the broadcast mode should be unchanged and work as usual with your ODE.
    Are you sure you didn't activate Unicast ?
    Sure that in Preferences, under DMX Output, Artnet is selected and the correct interface/IP address is set ?
    If all these do not work, you can try resetting MadMapper to factory defaults.
