video lose quality in madmapper
  • caracoisvoadores
    by caracoisvoadores » Fri May 23, 2014 6:45 pm
    I got a problem that is problably easy to solve but I don´t know how.
    I got some video files that export as photojpeg, with the hd size 1920 - 1080.
    I import them to modul8 and everything is fine.
    when I turn the syphon on and bring the videos to madmapper they lose allot of quality, could you let me know what is the problem.
    I have been on line going to tutorials, forum´s, etc but cannot find the answer.
    help
    Re: video lose quality in madmapper
    by franz » Mon Jun 02, 2014 6:57 pm
    what do you mean by loosing quality ?
    do you see compression artefacts ?
    do you loose precision in details ?
    M8 is sending to MM via Syphon, so there shouldn't be any loss in quality, as the images are shared on the graphics card.
    Maybe you're Syphoning out from M8 at a low resolution. Try to send bigger resolution frames (in M8, go to the preferences and enlarge the syphon output size)
