Hey Everyone,
Just a quick post. Has anyone been utilizing the Hap Codec since the release of 2.8?
Any noticeable difference's in play back? I will be doing some testing but interested to hear of other people's experiences.
Liam
Yup, just install the codec (https://github.com/vidvox/hap-qt-codec/releases/), and select HAP as the export option for your videos in media encoder or whatever you use to encode/export.How do I use it?, just install it and it will start using it or do i have to export mi videos and choose a HAP option as export, I dont really understand how to use it, can someone explain it to me
Been using a mix of PJPEG and HAP depending on the length and size of content.Any final word on HAP?
Pros and cons? Should I stick to photo jpeg?
Does it run smoother and does it consume less cpu than photojpeg ?
g.
