osc control over each quad corner
  • generalh
    by generalh » Sat May 31, 2014 4:10 pm
    hello dear madmappies,
    i would like change dynamically the shape during the show from a quad for example.
    Is it possible to access (x,y) parameters from a corner thru osc or midi ??
    Thank you
    H
    Re: osc control over each quad corner
    by sigmasix » Mon Jun 02, 2014 3:55 pm
    with the latest 1.6 yes you can!
    use cmd-L to open the assignation panel
  • generalh
    by generalh » Tue Jun 03, 2014 10:28 pm
    Hello Eric or Florian (? ;-))
    Thank you for the tip, I understand better the hoola hup didn't catch first this easy to connect tool.
    But as i have the first step, do you know if it's possible to access the whole points of NURBS surface once the bezier curve is activated?
    I would need a quad with bezier subdivision 2 2 and precision 2 the idea behind is to change a rectangle in a kind of wing of windmill.
    I have 8 rectangles on stage and i would like to make them turn at a certain moment but i need to change the shape.
    I'm already doing it with Jitter but for the sake of bringing the show on tour it would be easier for me to have the most part running under Mod8 and Mad.
    Quoiqu'il en soit...
    Thank you
    H
Users browsing this forum: No registered users and 83 guests
