osc feedback
  • generalh
    osc feedback
    by generalh » Mon Jun 02, 2014 11:46 am
    Hello madmappies,
    I'm sending osc messages from max to madmapper
    It works "fine" but there is only feedback from my messages
    for example i'm sending " /surfaces/moulin/opacity $1 "ranging $1 from -0.421 to 1,702 gives me opacity 0% to 100%
    and the message is automatically forwarded to my listening port which is fine but when change the slider in madmapper interface nothing is coming back.
    Is this normal or do i miss a parameter??
    Thank you
    cheers
    H
    Re: osc feedback
    by mad-matt » Wed Jun 04, 2014 5:12 pm
    I just check with TouchOSC and it works fine (getting feedback when changing opacity with the mouse). Are you sure you are not listening to the same port you are writing on ? In that case you would receive your own messages, and not MadMapper ones...
    Matthieu
