STARWAY DisD Processor 8
  • kashmir
    by kashmir » Sat Jun 07, 2014 1:09 am
    Im' trying to use a STARWAY DisD Processor 8 ( 8 univers Artnet) but i can't manage to connect to it;
    im' using a macbook pro retina with the thunderbolt ethernet.
    With the Enttec OPEN DMX i get it working Straight away.
    As anyone got an answer or experienced the same ?
    Re: STARWAY DisD Processor 8
    by franz » Sat Jun 07, 2014 2:53 pm
    I wouldn't generally recommend Starway products as they are quite cheap...
    When plugging it to your Mac, can you ping it ?
    Is it in the right address range ?
    I think you first have to configure it using the bundled software
  • kashmir
    by kashmir » Wed Jun 11, 2014 6:13 pm
    I had it passe over for free that why ;)
    I finally managed to connect it.
    I had to put the ip address : 2.16.0.3 on the thunderbolt ethernet (wich apparently is the fix address for this kind of ArtNet device) and it worked straight away !!
