i found another way:
you need to alter the size in the "editor" of the "text module"
if you open the editor , select the text module
in the visual tab click the little menu where you can enter the text size : enter 300 or 500
now press "cmd" "alt" R . The module is updated.
for me that works. If you push the resolution to 110 . It looks good .
- this is the Type, for me this looks good (it´s not that good as a grafik, i think)
- Bildschirmfoto 2014-11-27 um 08.49.11.png (67.76 KiB) Viewed 8969 times
- you need to click over resolution to activate it
- Bildschirmfoto 2014-11-27 um 08.42.31.png (12.95 KiB) Viewed 8970 times
- this is where you put the 300
- Bildschirmfoto 2014-11-27 um 08.42.22.png (28.3 KiB) Viewed 8970 times
i hope this helps you .
i was looking for this feature too ...
so thank you for reminding me that there are more options ...
