Help I still cant get my projector to work!
  • MikeGG
    by MikeGG » Wed Jun 18, 2014 10:56 am
    I am new to madmapper and I cant seem to output full screen to my projector. As with a few other people in this forum I get full screen on both my projector and computer screen at the same time. I've looked at the output and madmapper doesn't seem to be seeing my projector. I just get 'none' and 'LCD' on my outputs. I am using a USB cable to connect Macbook Pro to projector, would vga and adapter make a difference? Any help would be appreciated with a gig in less than a week! Thanks
    Re: Help I still cant get my projector to work!
    by sigmasix » Wed Jun 18, 2014 1:58 pm
    avoid usb display things, it's not a standard way to connect any projectors or display to a computer… DVI, HDMI, VGA, this is how you do
    also, check that the mirroring option is disabled in your display settings of the system preferences
  • MikeGG
    by MikeGG » Thu Jun 19, 2014 11:25 am
    Thanks so much, the usb cable caused all the issues. Thunderbolt to VGA and it all worked sweet as. :D
  • stuartmac
    by stuartmac » Wed Aug 20, 2014 10:45 pm
    had a similar problem with a TB to dvi and dvi to vga dongle it wouldnt work at all, bought the straight TB to vga dongle and away it went.
