Border around a video
  • monomixdown
    by monomixdown » Fri Jul 04, 2014 4:11 pm
    Hi guys,
    i would like to have a small white border around a resized video.
    Does anyone know the solution?
    Thanks
    hry
  • anomad
    Re: Border around a video
    by anomad » Fri Jul 04, 2014 8:38 pm
    . if you're only using the one video, you can set the ' background color' of the output in the bottom left corner of the main UI
    . alternatively, you can create a new layer and load the 'Modules -> Show -> Painter (layer)' module, draw the border than resize the video on a layer above the video clip.
    -james
    (a nomad. )
  • monomixdown
    by monomixdown » Fri Jul 04, 2014 9:43 pm
    Thanks James,
    but its a little bit more complicated.
    The border should appear and disappear with the video.
  • anomad
    by anomad » Sun Jul 06, 2014 12:20 am
    . if the white border needs to be around the video, why not just add the border to your footage ?
    -james
    (a nomad. )
