Ipad as input to MadMapper?
  • symbiosis
    by symbiosis » Sat Jul 12, 2014 8:28 pm
    Hey guys,
    Is there any chance of having an iPad screen as input into MadMapper?
    Even if not directly to MadMapper (ex: through Modul8 and Syphon), is there any way around?
    Initially I thought of using the hdmi connector, but couldn't make MM or M8 recognize it.
    Thanks
  • symbiosis
    Re: Ipad as input to MadMapper?
    by symbiosis » Sat Jul 12, 2014 8:41 pm
    Found this possibility online, the problem is it seems working only with live camera: (I need to output the ipad's screen, not its camera)
    first using an iPad as an input in CoGe using AirBeam and Syphon:
    http://www.cogevj.hu/blog/2012/iphoneip ... nd-syphon/
    And then connecting CoGe to MadMapper via Syphon:
    http://www.cogevj.hu/blog/2011/connecti ... ia-syphon/
    Anyone knows a better way around? I haven't tested this one still.
    Thanks
  • Xaver2k
    by Xaver2k » Fri Jul 18, 2014 6:49 pm
    hmm i think your question is not really clear, because using the ipad as an input... i would think you want it as a midi controller
    but i think you mean something totally different?
  • symbiosis
    by symbiosis » Fri Jul 18, 2014 7:41 pm
    Hi Xaver2k,
    The idea is drawing on the ipad and having its fullscreen output (via an hdmi connector or wireless) to be received in MadMapper or Modul8, do you know anyway of doing it?
    Thanks
  • JJHP3
    by JJHP3 » Sat Aug 09, 2014 2:53 am
    Yeah, something like TapTool on iPad would be great with MMper.
    John
    by ilan » Fri Aug 22, 2014 8:24 pm
    I have already used Tagtool with Airserver. As long as you are using a dedicated connection it's solid.
  • DavidDivine
    by DavidDivine » Thu Jun 06, 2019 3:23 am
    Can you share your step by step process to link Tagtool on iPad with mad mapper? Thanks!
    by mad-matt » Fri Jun 07, 2019 9:44 am
    TouchOSC is a great remote for MadMapper too (with OSC network protocol - MadMapper supports Bonjour discovery so setup is made easy)
  • tontechnik
    by tontechnik » Sat Feb 06, 2021 9:36 pm
    The App "NDI HX Capture" is exactly that, what you need. :wink:
