duplicate clip with sound (make instance) ?
  • sitosun
    by sitosun » Mon Jul 14, 2014 12:22 pm
    Hi!
    I have quite a simple question i guess.
    My setup is a triplehead panorama (3 projectors)
    i need to show one video with sound on the 1st AND on the 3rd screen.
    how can i manage this in modul8?
    i thought i have to duplicate that clip and arrange it on the space of the first and on the space of the third screen
    but the problem then is ... how can i start the two clips at the same time (so that the image and the audio is synchronized?
    also i would need only the sound source of one clip.
    is there a way to somehow make an instance of a clip .. like in resolume
    or is there a module which can do that job?
    guess there should be a solution as this seems to be a very common need.
    i hope i described in a clear way.
    thx for help
  • sitosun
    Re: duplicate clip with sound (make instance) ?
    by sitosun » Mon Jul 14, 2014 5:06 pm
    maybe it's not possible?
  • sitosun
    by sitosun » Tue Jul 15, 2014 10:09 am
    i thought its quite easy
    and true ... with the matrix tool and planar space .. it works
  • anomad
    by anomad » Tue Jul 15, 2014 7:07 pm
    . i thought of a few different ways to do what you were asking (using Syphon, rendering one large clip that spanned all the monitors), but i must honestly say - your solution is brilliant !! i never thought of using the matrix like that. :)
    -james
    (a nomad. )
  • sitosun
    by sitosun » Wed Jul 16, 2014 3:34 pm
    cool, thx;) .. the only problem with this solution is that the distance between the objects, which you can set by planar space, is very limited .. it probably fits my needs this time, but i wish i could extend that range
    by sigmasix » Fri Jul 25, 2014 12:08 pm
    you might be able to extend this distance by making a very simple module with a slider that has a larger max value than the default slider on the matrix options
