Switching between projects
  • vvilcina
    by vvilcina » Thu Jul 17, 2014 11:43 am
    Hi, I am making an installation, and wanted to ask is it possible to switch between to sets of videos..
    So I have made touch sensor which works with arduino, and the idea is when person touches piece of paper (sensor) the videos switches to other videos, so like a different project..
    Is there any way to do it? If there would be like a keyboard shortcut I am sure that would be able to connect with arduino..
    Thank you
    VIta
  • Xaver2k
    Re: Switching between projects
    by Xaver2k » Fri Jul 18, 2014 6:44 pm
    sure you can! you can use the arduino to "convert" the sensor signal in a midi signal (or as a serial in) and the midi signal can trigger a video in quartz composer or madmapper should also work.
