Two Artnet to DMX controller over ethernet switch?
  • te-c
    by te-c » Tue Jul 22, 2014 7:51 pm
    For my next project I am starting with Madlight.
    I need 8 universes for 22.5 Meter of adressable RGB LED stripes. The customer recommend me two of four*512 Artnet to DMX controllers.
    http://www.showjockey.com/product.php?id=196
    How can I connect two controllers on a MacBook Pro if I have only one Ethernet Port? I think I have to buy a Gigabit Ethernet Switch, right?
    Would be great if somebody can help me. With configuring the Ethernet Ports to my Computer.
    They also told me, that I don't need any dimmer, is it right that they are only working over DMX if they are adressable? Here are the name of the LED stripes Flexible LED Strips SJ-DMX-FSRGB-32 (HS9405409000)
    Thanks in advance.
    Re: Two Artnet to DMX controller over ethernet switch?
    by sigmasix » Fri Jul 25, 2014 1:43 pm
    yep, just use a network switch. I don't think you need a gigabit switch.
  • te-c
    by te-c » Fri Jul 25, 2014 7:25 pm
    Thank you! That helps, so I think I can make my LED stuff order.
  • Thelooca
    by Thelooca » Wed Sep 03, 2014 12:11 am
    Hi
    can you give a link/name/type of the controller of your digital led strips?
    thx!!
  • te-c
    by te-c » Wed Sep 03, 2014 7:58 pm
    You can contact showjockey. They are really great and helped me to find the stuff I need for my Installation. More informations soon.
Users browsing this forum: Google [Bot] and 6 guests
