MadMapper 1.6.3 Update
    by franz » Sat Jul 26, 2014 12:42 pm
    MadMapper 1.6.3 is available to all registered users.
    Download it from http://www.madmapper.com/yourspace
    ADDITIONS:
    + New option in Preferences / Misc: you can choose to show/hide the surface names in the export (for inputs or outputs).
    + Added new blend mode: multiply
    + Added OSC color channel support
    + Added Disable HID Devices (PS3/PS4)
    FIXES:
    Improvements in ArtNet:
    * Fixed Solved an issue when changing IP address while MM is running
    * Fixed With unicast: the list of network devices gets updated as soon as you select the network interface in preferences
    * Fixed With unicast: workaround for a problem in Enttec STORM software (sending IP 127.0.0.1)
    * Fixed Reset ArtNet devices when "Reset to factory defaults"
    * Fixed Solved a possible crash when entering an empty OSC address
    * Fixed bug reported by Aktion: UVs not initialized correctly when recalling a preset where a surface UVs are outside the input rect (viewtopic.php?f=20&t=9047)
    * Fixed Test pattern was always showing 800x600
    * Fixed Solved Quartz boolean parameter assignment
    * Fixed media pause button assignment
    * Fixed Solved an issue when loading projects created with MM prior to 1.6 with preset or surfaces that have empty names
    * Fixed Solved an issue when loading projects created with MM prior to 1.6 if multiple presets have the same name
    * Fixed Solved a possible crash when changing preset from an assignment
    * Fixed No need to restart the application when activating Syphon output
    * Fixed Bug fix in Media Controller (two issues: possible crash when removing several pictures fastly / when undoing deletion of a media the control nodes were not coming back)
