MadMapper 1.7 Beta b3734
    by franz » Sat Jul 26, 2014 12:47 pm
    MadMapper 1.7.0 Beta (buikd 3734) is available to all registered users who feel adventurous to test it.
    Do not use in production !
    Download it from http://www.madmapper.com/yourspace
    What's new in 1.7 ? Surface Groups, Lines and Soft Edge (about which we're working on a tutorial).
    Please report any problem to support@garagecube.com .
    Release notes 1.7.0 Beta b3734
    ADDITIONS:
    + Added groups to organise surfaces & fixtures
    + Added the possibility to transform multiple surfaces at the same time
    + Added Lines
    + Added DMX Line
    + Added soft-edge on quads
    + Added audio controllers (bass/medium/treble/amplitude channels)-
    + Added Leap Motion controller
    + Added a setting in the preferences/misc to be able to export the input or the output without the surface names
    + Added blend mode subtract
    + Added “controls” to trigger previous/next media per type (Previous/Next image, previous/next movie…)
    + Added audio input level slider in master tab
    IMPROVEMENTS:
    + Main projector will automatically switch to the first external screen (if not assigned manually)
    + Optimization: removed vertical sync on previews
    + Restore last selected tab when openging preferences dialog
    + The output windows are now resizable
    + When resizing a projector, keep top left corner in place (like when resizing stage)
    + Remove the different filters in "import media" dialog (enable all supported formats)
    + Moved the rotation, scale and other handles out of the surface to avoid bad manipulations when trying to use the content of the surface (Mesh for example)
    + Store “recent files” list not only when leaving the application
    + When copy/pasting several surfaces/fixtures, duplicates were in inverse order (and DMX addresses too, which can be annoying)
    FIXES:
    * Activating/Deactivating Syphon output does no more require a restart
    * Fixed a bug detecting screen configuration changes on OSX 10.9 and in some cases on previous OSX versions
    * With some QuickTime files, there were glitches in the Syphon output
    * Fixed Quartz Composer parameters restore (when reloading a file or when restoring preset)
    * Fix bug: The syphon size was defined by the window size and not the size given by the user in the Outputs inspector
    * Fixed an issue entering the dmx channel number in the “Controls” dialog
  • barneyb
    Re: MadMapper 1.7 Alpha
    by barneyb » Wed Sep 17, 2014 9:29 am
    I use Madmapper in a MAC Pro 2013 running 10.9.4, but seems to crash when I run 2 projectors assigned to 2 physical outputs. It crashes as soon as I start making surfaces. It is working in Madmapper 1.6.1
    Barney
  • luxcollective
    Re: MadMapper 1.7 Beta b3734
    by luxcollective » Thu Oct 02, 2014 11:13 am
    1.7 does not show up as a download option in my Yourspace (I registered as a Beta tester)
    broken
    by broken » Fri Oct 03, 2014 5:12 pm
    luxcollective wrote:1.7 does not show up as a download option in my Yourspace (I registered as a Beta tester)
    same for me as well. get an email saying I've been added, but my yourspace only shows a button to sign up as a tester again..
  • roboterrr
    by roboterrr » Tue Oct 21, 2014 11:31 pm
    Will the beta 1.7 run on OSX 10.6.8? It won't open on my computer.
    aktion
    by aktion » Wed Oct 22, 2014 5:32 am
    You will get an email with the download link in the form of Newsletter.
    AKTION STUDIO
    broken
    by broken » Wed Oct 22, 2014 2:57 pm
    aktion wrote:You will get an email with the download link in the form of Newsletter.
    Yup
    Just a bit odd the signup form still displays on the Yourspace page and doesn't link to an actual download.
    Would much rather see the beta in my Yourspace for download instead of through a link in my email if there's any option
