Transparency
  • VJ Ruby
    Transparency
    by VJ Ruby » Fri Aug 01, 2014 5:37 pm
    Hi everyone,
    I'm kind of new to Mod8, and I need some help figuring out how to make the white background on some of my clips "transparent." I've tried using Luma Key, but it doesn't exactly work. Is there any way to render all the white in a given clip "see-through"?
    Thanks :oops:
  • anomad
    Re: Transparency
    by anomad » Sat Aug 02, 2014 7:13 pm
    . when you activate 'Luma Key' - try clicking the second button underneath it, 'Luma K. Inv' -- that should make the white color transparent.
    -james
    (a nomad. )
    pele2010
    Re: Transparency
    by pele2010 » Tue Aug 05, 2014 12:19 pm
    Hi VjRuby ,
    i think you should "render" your clips with alpha channel. Then they are automatic transparent.
    Best is to use Quicktime codec "png" with alpha.
    here is a tutorial from deepvisual:
    https://www.youtube.com/watch?v=iDyxDRkjiVc
    And there is a new Codec for QT called HAP . This codec is graphic card optimized and is able to hold an alpha channel too.
    here is the download:
    http://www.modul8.us/2013/11/04/hap-codec-v2-available/
    here is a thread about codecs:
    viewtopic.php?f=3&t=8009
    i hope this helps you:
    there is a manual available which is very helpful because you can work with the software and read at the same time.
    well i found this helpful.
    you can buy it from "yourspace" where you also can buy the software and hardware
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
