Soft edges.
    tdog
    Soft edges.
    by tdog » Wed Aug 06, 2014 2:38 pm
    hi,
    i can't find the answer i need by search, so i'll ask a very specific question..
    How do I create a soft edge to my ( single ) projector output? not edge blending as such; just want to remove the hard edges of the projector output.
    In such a way that no matter what i do inside modul8, the output is alway masked.
    Thanks,
    tdog.
    By any means necessary....
    Re: Soft edges.
    by sigmasix » Wed Aug 06, 2014 3:51 pm
    There's a "Mask" module you can use to place a media on top of everything.
    You can create a png file that has the soft shape you need from black to transparent.
    tdog
    Re: Soft edges.
    by tdog » Thu Aug 07, 2014 9:02 am
    hi, thanks for reply;
    i'm trying with that module [mask (global) ?], but when i scale the master output, the mask doesn't scale with the output, so the images 'leak' over the edge..
    tdog
  • paullarry
    Re: Soft edges.
    by paullarry » Tue Jun 02, 2015 12:40 pm
    so have you fix that???? if not then may be i can help you out
    tdog
    Re: Soft edges.
    by tdog » Tue Jun 02, 2015 1:27 pm
    hi, been away a while....
    no, not fixed this issue.
