a module/script to change a movie of 2layers simultaneously?
  • nbd
    by nbd » Sat May 27, 2006 11:26 pm
    Hi !
    Is there a way to do the follwing:
    I have 2 layers.
    with a click in my media window I like to apply this movie to both layers.
    Is that possible? How?
    I am thinking of a module that links itself "between" the media window and the layer set?
    Thank you all!
  • nbd
    by nbd » Sun May 28, 2006 4:15 pm
    possible thought:
    one layer is accessed directly via the KeywordEvent :
    Code: Select all
    if keyword=='ctrl_layer_media':
    the other layer is correlated to that via:
    Code: Select all
    modul8.setValue('ctrl_layer_media',param,2)
    problem: 2.5 beta2 crashes with that code.
    crash log has been sent to beta25.[/code]
    by boris » Sun May 28, 2006 4:18 pm
    Maybe you can use the KeywordEvent (feedback) into the script.
    When one layer is changed you can change another.
    by boris » Sun May 28, 2006 4:21 pm
    Sorry I diden't see your answer :roll:
    We will check your crash, thanks !
    by boris » Sun May 28, 2006 4:36 pm
    Ok :P
    It's a python crash because you made a endless loop, is not a problem w/modul8 beta.
    You need to improve a litle bit your script :
    Code: Select all
    first add this on the init() :
    feedbackLock = 0
    and in your KeywordEvent :
    Code: Select all
    if not feedbackLock : feedbackLock = 1 if keyword=='ctrl_layer_media': modul8.setValue('ctrl_layer_media',param,2) feedbackLock = 0
    And now an endless loop is not possible and it works ![/code]
    by boris » Sun May 28, 2006 4:40 pm
    Sorry the 'TAB' seems to be not working into the forum...
  • nbd
    by nbd » Sun May 28, 2006 4:42 pm
    A great, I understand:
    the KeywordEvent is repeatedly called by itself, because it is reacting on the thing itself changes.
    THX !
  • nbd
    by nbd » Sun May 28, 2006 4:53 pm
    code with TABS:
    Code: Select all
    if not feedbackLock: feedbackLock = 1 if keyword=='ctrl_layer_media': modul8.setValue('ctrl_layer_media',param,2) feedbackLock = 0
    by boris » Sun May 28, 2006 6:02 pm
    Just add one "tab" , but it works also without...
    Thanks for the tips about "code", I update my message...
Users browsing this forum: No registered users and 59 guests
