Logical record greyed out
  • JJHP3
    by JJHP3 » Sun Aug 10, 2014 11:11 pm
    Hi Folks
    Surprising... '08 MacPro, OSX 10.9.4; latest M8. I hit record, and the logical record menu item is greyed out. Any ideas? Used it all the time in previous OS's and M8's. I fired up my older MacBookPro running 10.6.8 with the latest M8 and had the same greyed out choice. Must be M8? I can use Syphon Recorder, but I like the off-line aspect of logical record.
    Thanks,
    John
    (sorry I posted this to MadMapper by mistake earlier...)
    Re: Logical record greyed out
    by sigmasix » Mon Aug 11, 2014 1:16 pm
    is the logical record still recording when you try to render? this could be the problem
  • JJHP3
    by JJHP3 » Mon Aug 11, 2014 1:40 pm
    I don't think so. I press record. I press stop. I go to menu and it is grey. Here's what it looks like:
    by sigmasix » Mon Aug 11, 2014 1:46 pm
    are you recording the layer (small buttons) part or the master (big buttons way down the interface) part? you cannot render what you recorded on a layer…
  • JJHP3
    by JJHP3 » Mon Aug 11, 2014 1:47 pm
    Super embarrassing! I was pressing the smaller record button, not the correct, larger one at the bottom of the interface. Works fine now.
    Sorry for any trouble - lesson learned!
    John
