MM->Syphon Recorder = blinking!
  • JJHP3
    by JJHP3 » Fri Aug 15, 2014 3:06 pm
    Hi Everyone
    A couple of days ago, I was using Syphon Recorder (latest) to record MadMapper (latest) output, either streamed from M8, or a video clip and it worked fine. Now I prepare my mesh in MadMapper, output is good then I open Syphon and the output flickers or blinks dramatically. I quit Recorder and MM continues to blink. If I switch to internal camera in MM, that doesn't blink. Choose M8 or video clip, blink is back.
    Can not figure out what changed. I have tried all the variations I could think of in Recorder and MM without luck. New projects, different output in Recorder… I sent this problem to the Syphon list too.
    Any advice greatly appreciated!
    John
    -OSX 10.6.8-
  • magdesign
    Re: MM->Syphon Recorder = blinking!
    by magdesign » Tue Sep 02, 2014 11:11 pm
    Same here.
    Worked without any problem in OSX 10.7 until I upgraded to Mavericks 10.9, newest Syphon recorder b13, and MadMapper 1.6.3
    But the problem is not Syphon recorder, when I use MadMapper version 10.5.3 it works....
    Please try to fix guys!
  • JJHP3
    by JJHP3 » Wed Sep 03, 2014 4:12 am
    Thanks for the input. Nice to know it is not all my incompetence.
    John
  • magdesign
    by magdesign » Fri Sep 05, 2014 1:59 pm
    After mailing with the support team, I got following answer:
    There's a frame synchro issue with MadMapper 1.6.3 that causes black and white frames with Syphon.
    We will fix that soon.
    Thanks for your report
    Gael
    GarageCUBE Team
