display link problem
  • Mr. Dzerve
    by Mr. Dzerve » Mon Aug 18, 2014 7:19 pm
    Hi! when i connect AOC 16" - E1649FWU with USB connection as main monitor to my new Mac Pro, Modul8 freezes on startup. All other applications working as usual with no problems.
    Re: display link problem
    by sigmasix » Tue Aug 19, 2014 10:47 am
    usb is not the way to go to connect a display on a computer… your mac won't activate the graphic card in this case and modul8 needs it to work.
  • Mr. Dzerve
    by Mr. Dzerve » Tue Aug 19, 2014 12:40 pm
    Thank you sigmasix! at studio i have samsung S27B970 Display, but for my gigs i need something small and light to put in my backpack, so i decided for cheap usb monitor. i have a lot of venues where i have to come with my Mac Pro and big monitor is not the best way to go... i have to find another way. strange that all other applications including madmapper is working just fine.
    by sigmasix » Wed Aug 20, 2014 2:05 pm
    first versions of madmapper had the same problem.
    I think it's a way to use the graphic card that causes some problems. not many apps are that much gpu oriented
Users browsing this forum: Baidu [Spider] and 9 guests
