PS3/4 controller issues
  • texicwaste13
    by texicwaste13 » Mon Sep 08, 2014 3:09 pm
    I am having trouble getting the PS4 controller to learn functions. It will not hold anything I try to get it to learn, it just reverts to 'y" or "x" after I tell it to learn a function and assign it to a button or arrow. also, when I go to the surfaces it does nothing. Help please? I got it into my imac through bluetooth in the system preferences, should I be using the usb to get it to learn functions and then go wireless ( bluetooth)?
    Re: PS3/4 controller issues
    by franz » Fri Sep 12, 2014 11:22 am
    I believe your analog stick is a bit jaggy, flickering a bit so prevents the auto learn to work correctly.
    I guess you'll have to manually assign your controls to the wanted button.
    Use the usb at first, don't forget to press Home to activate the controller.
  • texicwaste13
    by texicwaste13 » Thu Oct 23, 2014 5:57 pm
    i have tried everything, and it just does not accept any learn functions.
  • Sumeraxe
    by Sumeraxe » Thu Mar 26, 2015 7:05 am
    hi, same problem with me please suggested me....!!!
    We are the leading the world in providing best http://test-king.com/ dumps prep solutions. Our incredible offers for and gedare accessible at reasonable prices; our Florida National University is very rare in IT world.
    by franz » Mon Mar 30, 2015 2:27 pm
    don't use learn and use the mapping list (command - L),
    then apply manually to your buttons.
