MadMapper Update 1.6.5
  • garageRoot
    by garageRoot » Tue Nov 04, 2014 7:07 pm
    Version 1.6.5 (build 3887)
    FIXES:
    * Fixed syphon output size when changing projection resolution
    * Possible issue when changing projector resolution
    Version 1.6.4 (build 3823)
    ADDITIONS:
    + Optimised Controls Dialog
    FIXES:
    * Solved issues with empty or duplicated surface/preset names when reloading projects prior to 1.6
    * Fixed an issue when validating an empty osc address
    * Fixed media pause button assignment
    * Solved an issue with boolean Quartz parameter assignment
    * Test pattern was always showing 800×600 in the outputs, now show projector size
    * Fixed crash when pressing TAB when an incomplete graphic item is being edited
    * ArtNet:
    – It was necessary to restart MadMapper after changing computer IP address
    – Improved preference dialog for ArtNet unicast
    – Reset ArtNet population when resetting preferences
    aktion
    Re: MadMapper Update 1.6.5
    by aktion » Mon Nov 10, 2014 8:51 pm
    AKTION STUDIO
    by franz » Wed Nov 12, 2014 4:03 pm
    thanks, we'll fix this !
  • kashmir
    by kashmir » Thu Dec 04, 2014 12:46 am
    i just got a Storm24. If i dont use unicast i cant send him anything is it normal ? Means i will have to set all the universes used one by one ?
