Slow performance on new MacPro
  • vjspetto
    by vjspetto » Mon Nov 17, 2014 10:45 pm
    I am testing MadMapper with six monitors attached, 1280x720 each in a New MacPro (the black trashcan) 3.5mhz, 6core, 32gb Ram, 2 * d500 videocards
    Performance is really slow, about 12 fps.
    My projectors config in MadMapper is: 5 output monitors
    5 slices redirected to the 5 monitors.
    When I turn off each of the monitors the performance goes a bit better.
    System is 10.9.5.
    Any ideas?
    //vj.spetto//
    UNITED VJS
    Re: Slow performance on new MacPro
    by sigmasix » Wed Nov 19, 2014 12:05 pm
    what resolution?
    if you're 6 times fullHD it makes a lot of pixels to handle…
  • te-c
    by te-c » Wed Nov 19, 2014 1:19 pm
    Any specifications you can recommend if I would buy a new Mac Pro?
    More Money to spend in CPU, GPU or RAM?
    I'm working most of the time with modul8 and MadMapper with three HD Outputs and Madlight with 5 Universes live.
    For Building constructions I work with C4D and After Effects CS 6.
    by franz » Sat Nov 29, 2014 2:22 pm
    I have a MP 2xD700, 6 outputs (4x 1024*768 + 2x full HD), running off a 1400*2048 syphon, everything runs at a solid 30 FPS minimum.
    Still, that's a lot of pixels ... ! Don't expect miracles (such as 60 FPS)
  • te-c
    by te-c » Sat Nov 29, 2014 3:40 pm
    Which CPU do you have and how much RAM?
    by franz » Fri Dec 05, 2014 11:08 am
    I have a 6-core CPU + 32 GB RAM, running under 10.9.x -- don't Yosemite yet --
  • te-c
    by te-c » Fri Dec 05, 2014 8:46 pm
    Got the same maschine on work but with less RAM. Hopefully I have enough Money to buy one for myself.
