Copying Surfaces output values
  • stocha
    by stocha » Tue Nov 25, 2014 8:09 pm
    I am trying to use Madmapper with several inputs, basically switching between sevral syphon sources. Since each source is different, I need to have different input surfaces. But my output should always be mapped to the same shape.
    The question is: Is there a way to copy an output surface and assign it to different input surfaces ?
    Or how would people go around this, i.e different input shapes to same output map
    Could not find anything on the board, hope that someone can help. Thanks
    aktion
    Re: Copying Surfaces output values
    by aktion » Tue Nov 25, 2014 8:37 pm
    Use Presets .. and then switch between them .. I hope this info is enough for you to get what you are looking for.
    AKTION STUDIO
  • stocha
    by stocha » Wed Nov 26, 2014 10:39 am
    Hi Aktion, thanks for the reply, but it does not solve my problem.
    I will try to better explain with a simple example of what I am trying to do:
    - I have two inputs. Let's say a 4:3 camera and a 16:9 camera
    - I am mapping both of them onto a sofa or whatever 'slightly curved' shape on stage. I have one preset for each.
    - Every time I setup the stage the sofa and projectors will be at a slightly different position. I will warp the output of my surface accordingly.
    And here is what I do not find a way to do. Once I warped for one of the presets, how can I just copy the warping to other surfaces/presets .
    Is it at all possible ? Else this would be afeature request for me ;)
    Thanks
