timecode genarator visual ?
    pele2010
    by pele2010 » Tue Nov 25, 2014 8:35 pm
    Hi all,
    i was wondering if it is possible to create a timecode generator. One that is recordable .
    It would be great for all kind of stuff.
    You could visually measure the delay or latency of 2 computers
    And you could actually use it for creating quit nice visuals too.
    i generate my time codes with after effects but i am dreaming of a generator inside of MD8.
    Anybody out there that helps me with this little project ?
    specs:
    generates numbers from 00:00:00:00 to 99:99:99:XX (depends on Framerate) (time can be altered)
    can be overlaid
    font can be selected
    font size change
    framerate can be selected (not a must but nice)
    Box can be around or not
    thanxs pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    pele2010
    Re: timecode genarator visual ?
    by pele2010 » Mon Dec 08, 2014 9:17 pm
    Anyone that knows how to do the timecode in QC or in python ?
    Maybe this could help to implement it into MD8 ....
    Can´t find a QC timecode....
    would be greate to get some help on this.
    thanxs
    pele
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • .lov._
    by .lov._ » Tue Dec 09, 2014 9:27 am
    This is just a receiver for QC, but Vezér can send MIDI timecode: http://cogevj.hu/forums/viewtopic.php?f=14&t=1944#p5641
    Vezér - timeline and control software for visual artists
    pele2010
    by pele2010 » Tue Dec 09, 2014 9:57 am
    Thanxs, ill give it a try.
    pele2010
    #eachfilm01
    #pele2010
    www.eachfilm.de
    deepvisual
    by deepvisual » Tue Dec 09, 2014 1:38 pm
    pele2010
    by pele2010 » Tue Dec 09, 2014 2:01 pm
    Thanxs Deepvisual,
    it´s good to know this source.
    the idea was not to use a video source. It would be great it the Tc generates.
    basically it would be great if we could generate numbers or timecodes from
    within a module.
    anyone that knows if this is possible with freeframes ?
    thanxs
    pele2010
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • anomad
    by anomad » Tue Dec 09, 2014 5:30 pm
    . i suppose if you want to dedicate a layer to the task, you could just write to the Text Module based on the position of the timePostiion of a different layer…
    . it looks like you can access number of frames, fps, length in the 'info_layer_media_****' keywords and determine the position via 'direct_layer_media_timePosition' (as a percentage of the total frames) then convert that to HH:MM:SS:FF - but, it would speed up/slow down based on the video clip speed and perhaps performance of Modul8 (but, it would work in reverse as well)
    . is that what you're thinking of ?
    -james
    (a nomad. )
Users browsing this forum: No registered users and 46 guests
