Live HD stream pb with GoPro DSLR and BM intensity shuttle
    mylene ViJette
    by mylene ViJette » Fri Nov 28, 2014 7:47 pm
    I want to use a HD stream in modul8.
    I have
    a DSLR (canon 600D)
    a go pro hero 3+
    a MacBookPro 15" retina (10.9.5)
    As both of my cameras have hdmi output I bought the black magic intensity shuttle (thunderbolt)
    It's not working !!!
    the hdmi signal from Canon is 1080 i 59.94 (even if I change the resolution in the camera, and I'm in pal!!!) so I have an interlaced signal in modul8 and it's not nice at all (is there any deinterlace modul ???)
    The hdmi signal from the gopro is still a mystery for me as I never had any image in the mac.
    I called both support, black magic and go pro and the response is that it's not compatible :-(
    I'm very disappointed and I'm still looking for a (cheap) solution, especially for the go pro because It's part of an interactive installation I need to use soon.
    Do you use HD input ? how ?
    Thanks for your help and comments :)
    Mylene
  • te-c
    Re: Live HD stream pb with GoPro DSLR and BM intensity shutt
    by te-c » Fri Nov 28, 2014 8:59 pm
    Did you try this solution?
    https://github.com/v002/v002-Camera-Live
    Combine your dslr to the computer with the usb cable and start the app. Choose the syphon channel in modul8 and the camera have no lag.
    mylene ViJette
    by mylene ViJette » Sat Nov 29, 2014 12:52 am
    Thank you,
    I will try it.
    I found also this " Canon2Syphon " but seems to be challenging for my computer
    and for the go pro I have an image with this setting
    720p 120 on gopro
    720p 59,96 on blackmagic
    More ideas welcome as I don't really like the 120fps setting
    deepvisual
    by deepvisual » Sat Nov 29, 2014 8:34 am
    i had BM problems with VDMX and an intensity studio.
    the work around was to install the previous version of BM software.
    ( version 9.x instead of 10.x)
    might be worth a try
