Madmapper crashes on Midi control mapping
  • moistattention
    by moistattention » Fri Nov 28, 2014 9:47 pm
    Is anyone else experiencing this? When I turn on midi controls and start assigning my projects to my midi controller Madmapper will freeze up and crash. Sometimes multiple times before I can get it at set and saved.
  • ProjectileObjects
    Re: Madmapper crashes on Midi control mapping
    by ProjectileObjects » Thu Jan 22, 2015 8:52 pm
    I have not encounter crashing issues, but I have seen odd performance issues when it comes to Madmapper and Midi. I used to assign individual layers to midi controller buttons, but the frequency of them working when I pushed them was random. I had to start making presets for every setup that I wanted to alter between and then using keyboard numbers 1-9 to activate the changes. Needless to say, if your experiencing crashes, and me performance issues, then something is still a bit odd with MM and Midi. Did you try routing through OSC with something like Osculator?
    -p.o.
    by mad-matt » Thu Mar 05, 2015 3:33 pm
    Hi p.o,
    Did you send crashlogs ? Yes yes, with what email address ? If not you can also send it to support, I'll check that.
    There is no such problem known.
    Thanks,
    Regards,
    Matthieu - MM team
