Controller "relative data" into numbers between 0 and 1 ?
    pele2010
    by pele2010 » Sat Nov 29, 2014 7:19 pm
    i am having trouble with a controller. It gives only relativ data (increment and decrement) .
    is it possible to convert them with python into numbers between 0 and 1 ?
    my nobs are jumping around from 0 to top level but nothing in-between.
    it took me ages to identify the problem....
    some help would be great.
    thanxs
    pele
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    Re: Controller "relative data" into numbers between 0 and 1
    by vanakaru » Wed Dec 10, 2014 11:04 pm
    Install MIDI Monitor.
    Some rotary controllers like DJ scratch ones send 1 when turned clockwise and 0 when turned counter cw any time you touch it. And nothing else. To get this to work for scratching in M8 you need to recode it. Look in the net, I have seen some tips how to do this.
