MadMapper Update 1.6.6
  • garageRoot
    by garageRoot » Tue Dec 02, 2014 5:26 pm
    MadMapper has been updated to Version 1.6.6 (build 3948)
    If you are a registered user you can download it from the yourspace page http://www.madmapper.com
    This version focuses on MadMapper performance improvement with OS X Yosemite (10.10)
    IMPROVEMENTS:
    + Performance improvement: removed vertical sync (VBL) on previews
    FIXES:
    * Solved an issue: in some conditions, when switching from another application to MadMapper, a preset could be triggered
    * Solved a major performance issue on Yosemite (OS X 10.10)
    * Solved compatibility of PS4 controller Yosemite (OS X 10.10)
    * Fix problem with mask in quad. Before this, after creating a mask in a quad if we select edit mask, the first click to the mask will move the mask away from the mouse.
    * Solved application signature for 10.9.5 & 10.10
