Modul8 crashing when playing HD loops
  • jason5d
    by jason5d » Sun Dec 28, 2014 5:25 pm
    M8 is quitting suddenly when I load up some hd footage
    If i load up 1 loop at time and wait for it to finish loading without doing anything its usually ok
    Hardly ideal.
    It stops happening when I change each loop to play "direct to disk"
    Can u add a global direct to disk option in the preferences
    This is on a brand new 2014 retina laptop with 2.5ghz i7 16gb 512gb pcie ssd running maverick playing photo jpeg loops
    Does anyone have any other suggestions on solutions in the short term
    macbook pro 2015 2.5ghz i7 16gb 512gb r9 2gb
  • anomad
    Re: Modul8 crashing when playing HD loops
    by anomad » Sun Dec 28, 2014 11:13 pm
    . try adjusting the values in the 'Medias' tab in the 'Preferences' window… set the values to be lower than they are currently set to force them to play direct from disk…
    -james
    (a nomad. )
  • jason5d
    by jason5d » Mon Dec 29, 2014 3:45 am
    works....ta
