Reverse Output Image
  • Intelliki
    by Intelliki » Fri Jan 02, 2015 12:25 pm
    Is there a setting in Modul8 which can allow me to reverse my output image?
    I was projecting a one minute countdown before midnight but my projector's image was reversed (It was connected to a splitter which was projecting onto 3 screens).
    Is it that the projector was not set up properly?
    In the end I saved the night by using the rotate setting from right to left and right to left etc… so that my numbers were readable to the crowd.
    But it was more difficult with my "Happy New Year" loop!
    I'd very much appreciate your feedback.
    Many thanks
    Re: Reverse Output Image
    by vanakaru » Mon Jan 05, 2015 11:59 am
    Your projector was not set up properly most likely. Did you not check it prior the show?!
