. new module '120 polygons v0 10'
  • anomad
    by anomad » Tue Jan 06, 2015 7:20 am
    . i was experimenting w/the painter functions and came up w/the module '120 polygons v0 10' which draws a number of polygons of 3-12 sides each around the center of the canvas. running in random mode will slowly increase the distance from the center of the screen.
    . the code was designed so that the starting point of the polygons would 'point' towards the center. for example drawing four polygons with three sides each (triangles) would result in all of them pointing towards the center.
    . the even and odd buttons refer to using only even or odd numbers for both the number of polygons and number of sides
    . here's a video capture - https://vimeo.com/116034378
    . any comments/suggestions are welcomed
    -james
    (a nomad. )
    pele2010
    Re: . new module '120 polygons v0 10'
    by pele2010 » Tue Jan 06, 2015 5:13 pm
    Bam!
    I think I got hypnotized ! The name of the module must be changed!
    120 hypnotic danger
    man , i looked into the eyes of kaa
    maybe 120 aka´s eyes ....
    this is absolute brilliant.
    thanxs for sharing it.
    pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
