Send keyword or OSC reference Method via OSC?
    pele2010
    by pele2010 » Sat Jan 17, 2015 2:17 pm
    Hey,
    is it possible to send the position of a Modul8 slider (e.g. global speed)
    to an OSC Device.
    I have the function and the method (range)
    but I don´t know how to connect this in the module with the OSC device?
    Background is:
    if you feed in a signal from an external source you don't have access to the speed or effect of this signal. (effect that
    the external device is able to generate)
    If we could send a signal , we could use a module to control the values.
    If this is mapped to a midi interface then we could use touch and sliders in one workflow.
    Any help appreciated
    pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
