10 Universe Art Net Setup Help
    lotech
    by lotech » Thu Jan 29, 2015 1:16 am
    For an upcoming festival we're planning on using 86 Versa/Happy Tubes, they're 16px which means that each tube takes up 48 channels of DMX. Based on that it means we need 4128 Channels total, which split over a 512 universe setup will need just over 8 universes. I'm looking at getting a DMX-King eDMX8 (https://shop.dmxking.com/eDMX8_p_36.html) which supports 8 channels of art.net via a rack mount controller.
    My question is -
    What the largest Art.Net channels people have used out of MadMapper?
    Can you reliably use 2 art.net boxes out of Madmapper or would it be wiser to drop a few tubes and just deal with the 8 the eDMX support?
    Any pointers would be great.
    Re: 10 Universe Art Net Setup Help
    by franz » Thu Jan 29, 2015 5:48 pm
    We used 22 universes for MAD_Orb project.
    The Enttec Strom has 24 universes output.
    ghostofelvis100
    by ghostofelvis100 » Thu Jan 29, 2015 8:30 pm
    I have a project on the go atm using a mere 5 full universes.
    I bought a 6 channel unit & a bunch of decoders made by this guy:
    http://stores.ebay.co.uk/juryshef?_trks ... 7675.l2563
    It would be good for you to write to him and get his advice. My art net unit cost me £85 off eBay from him for 6 universes, and he offers to build to spec! Very knowledgable individual. You won't need to spend hundreds to achieve what you want. Works fine with MadMapper. You could run 2 from a wireless router giving you 12 wireless dmx universes for about £200!
    good luck
  • Xaver2k
    by Xaver2k » Fri Jan 30, 2015 10:35 am
    Hey my biggest project with madmapper has been with 8 universes, i used 2 controller from the same guy as ghostofelvis100 (but the artnet-ws2811 edition)
    they are easy to configure via webbrowser, and the price is unbeatable! ^^
    lotech
    by lotech » Sat Jan 31, 2015 1:06 am
    Thanks everyone. It seems the tubes also come with a Enttec Datagate Mk1 which will do 8 Universes so no need to source a separate box.
    To keep it all simple I'm going to drop a few tubes to keep in under 8 universes.
