MadMapper 1.7 Release
  • garageRoot
    by garageRoot » Mon Feb 16, 2015 5:28 pm
    MadMapper 1.7 has been released.
    You can download the demo version from the MadMapper home page or download the full version from your madmapper's yourspace page
    http://www.madmapper.com/yourspace
    The minimum Operating system required to run version 1.7 is OS X 10.7 (lion)
    ADDITIONS:
    + Added groups to organise surfaces & fixtures
    + Added "Mad" Lines
    + Added DMX Line
    + Added soft-edge on quads
    + Added blend mode subtract
    + Added the possibility to transform multiple surfaces at the same time
    + Added audio controllers (bass/medium/treble/amplitude channels)-
    + Added audio input level slider in master tab
    + Added a setting in the preferences/misc to be able to export the input or the output without the surface names
    + Added Leap Motion controller
    + Added “Disable Leap motion support” option in Preferences / Misc (so that another application can use it)
    + Added OSC Flag
    + Added OSC Color single channel (RGBA)
    + Added “controls” to trigger previous/next media per type (Previous/Next image, previous/next movie…)
    IMPROVEMENTS:
    + Main projector automatically selects the first external screen if not assigned manually
    + Restore last selected tab when opening preferences dialog
    + Optimization: removed vertical sync on previews
    + When resizing a projector, keep top left corner in place (like when resizing stage)
    + Simplified Import media dialog (Removed media filters)
    + Moved the rotation, scale and other handles out of the surface to avoid bad manipulations when trying to use the content of the surface (Mesh for example)
    + Store “recent files” list not only when leaving the application
    + When copy/pasting several surfaces/fixtures, duplicates were in inversed order (and DMX addresses too, which can be annoying)
    + Number of Quartz parameter controls can be changed with setting quartzParameterNodeCount (i.e. “defaults write com.garagecube.MadMapper 40”)
    FIXES:
    * Fixed glitches in the Syphon output with some QuickTime files
    * Fixed Quartz Composer parameters restore (when reloading a file or preset recall)
    * Fixed issue when detecting screen configuration changes on OSX 10.9 and in some cases on previous OSX versions
    * Activating/Deactivating Syphon output does no more require a restart
    * Fixed syphon size was defined by the window size and not the size given by the user in the Outputs inspector
    * Fixed an issue entering the dmx channel number in the “Controls” dialog
Users browsing this forum: No registered users and 76 guests
