Update to new version
  • morph
    by morph » Tue Apr 07, 2015 4:28 am
    Any one got any tips on updating to a new version of Modul8 while keeping all your workspaces/modules/plugins intact from the last version.
  • anomad
    Re: Update to new version
    by anomad » Tue Apr 07, 2015 2:59 pm
    . i usually go to my Applications/ folder and rename Modul8 to Modul8 v2.???
    . then copy the new version into Applications/
    . then open two windows (old version and new version) and hold down option when dragging old modules/plug-ins to the new version (holding down option makes a copy, rather than moving the files) - going folder by folder and not copying unused or test modules.
    . probably not the most efficient method, but i've just gotten into the habit of doing it this way. :)
    . if you use the Inside Us All (iua> ) free frame plugins, there are a few extra steps to make sure everything is installed correctly.
    -james
    (a nomad. )
    broken
    by broken » Wed Apr 08, 2015 2:52 pm
    I normally just make a copy of my Modules folder to my desktop, and then drag it back in to my Modul8 folder once the new version is installed.
    Haven't had a problem with my workspaces or modules. I don't use any plugins
