. i've modified the OSC native (global) module and added some new code into DirectEvent
. i then created a basic template in Touch OSC to send a button, fader, and toggle
Code: Select all
if oscReceive and type == 'OSC':
addr = param['address']
args = param['args']
if log : print "RECEIVE : ", param
try:
oscToModul8(param['address'], param['args'])
except:
pass
if addr == '/1/push1' :
modul8.setValue('ctrl_master_invColor', args ,10)
if addr == '/1/fader1' :
modul8.setValue('ctrl_layer_scale_uniform', args, 1)
if addr == '/1/toggle1' :
modul8.setValue('ctrl_layer_pixelFX_blurOn', args, 1)
. however, '/1/fader1' causes the scale on layer 1 to jump to full and not move at all. when i run the log, the incoming data looks correct :
Code: Select all
RECEIVE : {'timestamp': 978979.76699999999, 'args': [0.87362635135650635], 'address': '/1/fader1'}
RECEIVE : {'timestamp': 978979.78799999994, 'args': [0.86538463830947876], 'address': '/1/fader1'}
RECEIVE : {'timestamp': 978979.80099999998, 'args': [0.85439562797546387], 'address': '/1/fader1'}
RECEIVE : {'timestamp': 978979.81700000004, 'args': [0.84340661764144897], 'address': '/1/fader1'}
RECEIVE : {'timestamp': 978979.83400000003, 'args': [0.83241760730743408], 'address': '/1/fader1'}
RECEIVE : {'timestamp': 978979.85100000002, 'args': [0.82417583465576172], 'address': '/1/fader1'}
RECEIVE : {'timestamp': 978979.86699999997, 'args': [0.81868129968643188], 'address': '/1/fader1'}
RECEIVE : {'timestamp': 978979.88399999996, 'args': [0.81318682432174683], 'address': '/1/fader1'}
. am i missing something basic here ?
-james
(a nomad. )
