Disable ShowJockey device support in settings
    cansik
    by cansik » Mon Apr 27, 2015 9:55 pm
    It would be great if you would develop an option to disable the ShowJockey Device support.
    My scenario is following: I want to send the DMX data through ArtNet to my own node, process the data and send it to the ShowJockey device. This works great, but if MadMapper starts before my node & usermode driver, MadMapper locks the device and never unlocks it. Even if it is not selected in the DMX Output settings, I'm not able to access it.
    Maybe a solution would be to call "UsbIO.closeShowJockeyDevice()", if it is not selected in the DMX output settings.
    Would be great to see that feature in the next release!
    Re: Disable ShowJockey device support in settings
    by mad-matt » Thu Apr 30, 2015 10:04 am
    Ok, that's fixed, future releases will have that fix. Thanks for the precious feedback !
