Locked 2 posts Page 1 of 1
Thin White Outline on MapMapper ext projector
  • James927
    by James927 » Sat May 23, 2015 10:46 pm
    Hi - I'm getting a thin white outline surrounding the image from my external projector when using MadMapper. I don't get this outline on the external projector image when using quicktime or VLC. I'm a Madmapper newbie but have looked through the FAQs and forum as well as online tuts. Any help is greatly appreciated.
    Thank you - James
    Re: Thin White Outline on MapMapper ext projector
    by franz » Sun May 24, 2015 10:45 pm
    maybe "show info" is enabled.
    disable it and you're good to go
