Performance Lag? V1.7.3, OS 10.10.3
  • nicholasrivero
    by nicholasrivero » Thu Jun 04, 2015 7:10 pm
    Hey everyone. I seem to be having some decreased performance issues. Trying to trouble shoot. I've heard reports that OS 10.10.3 causes some issues. Wondering if I should downgrade to OS 10.9.X?
    Currently running:
    Mac Pro (2013/Trash Can): 3.5 6 Core, 32 RAM, 512 HDD, D500
    OS: 10.10.3
    MM: 1.7.3.4628
    Outputs: 4x 1920x1080: 3 HDMI, One DVI.
    Playback: Have tried various different apps, Resolume, VDMX, ProPresenter V6.
    The machine is new, so it just has these apps installed, along with, most recent version of BlackMagic drivers, otherwise, no additional drives/apps.
    broken
    Re: Performance Lag? V1.7.3, OS 10.10.3
    by broken » Thu Jun 04, 2015 7:24 pm
    Have you disabled AppNap? http://www.maclife.com/article/howtos/e ... le_app_nap
    not sure if that would be the lag/performance issue though since you weren't specific about what was under performing/lagging..
    low fps? loops not seamless? playback slower than expected?
  • nicholasrivero
    by nicholasrivero » Thu Jun 04, 2015 9:58 pm
    Per your note, I did disable app nap. It seems to have helped, but not fixed the issue.
    The issue is low FPS. It doesn't seem to be running at a full 60 FPS. However, at some moments, FPS performance seems to come and go. Files are ProRes LT. No tearing on screens, just lower FPS.
    by franz » Thu Jun 04, 2015 10:12 pm
    we upgraded the playback system in 2.0 so it should be way faster now.
  • nicholasrivero
    by nicholasrivero » Thu Jun 04, 2015 10:26 pm
    Thanks Franz. I was trying out the beta, but decided not to use it on this event just yet. I definitely noticed the performance upgrade.
Users browsing this forum: No registered users and 57 guests
