USING A HARDWARE SEQUENCER
  • kirama
    by kirama » Fri Jun 12, 2015 2:35 am
    I was wondering if I can use Arturia Beatstep Sequencer with Modul8 to trigger video ?
    http://www.arturia.com/products/hybrid-synths/beatstep
    Thanks !
  • samulj
    Re: USING A HARDWARE SEQUENCER
    by samulj » Thu Jul 23, 2015 12:17 am
    I suppose the Beatstep should work just as any other midi controller. Just connect it to your computer, enable the input in Modul8 Preferences > Key Midi Mapping, and map midi controls to suit your needs.
    I've never tried Modul8 with a hardware sequencer, but I've used Ableton live to trigger Modul8.
  • anomad
    by anomad » Thu Jul 23, 2015 7:20 pm
    . yes you can. i hooked up a BeatStep Pro (via USB) to my laptop running Modul8 and i was able to receive MIDI from it.
    -james
    (a nomad. )
