anyone used madLight with PixelPusher?
  • QBall9
    by QBall9 » Sat Jun 13, 2015 12:44 am
    Hi - has anyone used MadLight for mapping LEDs via pixelPusher to RGB led strips?
    I can't find any info about this via searches etc., so any input would be appreciated!
    Thanks in advance... :idea:
  • Xaver2k
    Re: anyone used madLight with PixelPusher?
    by Xaver2k » Mon Jun 15, 2015 11:03 am
    On the Pixelpusher website, they write:
    We supply a free, portable bridge app that makes PixelPusher's advanced protocol work with Art-Net and E1.31, so you can drive tens of thousands of pixels from a professional lighting console or media server.
    so it should be no problem to run it via artnet.
  • QBall9
    by QBall9 » Tue Jun 16, 2015 4:02 am
    Thanks very much for your reply, Xaver2k.
    Well I assume that it's possible, but wondering if there's anybody out there who has actually used PixelPusher with MADlight, who might be able to consult with me on the subject.
    My skills with artnet etc. are non-existent.
    If anyone reading this post has used PixelPusher etc., hope you'll let me know!
  • Xaver2k
    by Xaver2k » Thu Jun 18, 2015 3:38 pm
    don´t be afraid of artnet... it´s not a deamonal force :twisted: . Artnet is your friend, you have to trust him! hahahaha :mrgreen:
    just give it a try, you need a network card and a network cable and some ip configuration on your computer side. you can be the first :wink:
    and you have to ask pixelpusher what they need to setup artnet on the device and how difficult it is.
  • BeamArt
    by BeamArt » Wed Jul 15, 2015 2:40 pm
    I am using PixelPusher with MadLight.
    It's pretty easy using the ArtnetBrige from PP.
    One thing I find annoying is that Mad_Light cannot cut a led panel across multiple universes... Or maybe I missed something?
    Benjamin
