Create animation effect
  • stephanie
    by stephanie » Sun Jun 28, 2015 12:19 pm
    I work with Madmaper and Modul8 with Syphon. I would like to make an animation with the successive appearance of different modules. I saw that there is a simple tool on the software HeavyM. You can number each face and control their appearance : https://www.youtube.com/watch?v=OjSBk1W7sNs:
    Is it possible to get this kind of effect with MadMapper? Do I can only use the technique of the overall mask to do this kind of effect with Madmapper? But il will not be the same effect... It would be really nice if someone can recommend me a tutorial or a idea to help me to make it please...
    Thanks a lot for you for your help
    Stéphanie.
