buy and ipad for Modul8 with TouchOSC
  • vjbelamy
    by vjbelamy » Mon Jun 29, 2015 11:43 am
    hello
    I would buy an ipad to install touch osc and make it work with Modul8 - according to your experience, if I buy an ipad mini 16gb (there are some very good prices in the shops) go well with the software mentioned above? or should buy an ipad standard with larger display and with different performances? thanks
  • anomad
    Re: buy and ipad for Modul8 with TouchOSC
    by anomad » Tue Jun 30, 2015 4:24 pm
    . i've had a lot of success using TouchOSC w/Modul8 (one way - from iPad to Modul8) using MIDI but will be messing around more w/OSC since it is standard in Modul8 v2.9.
    . don't forget the TouchOSC also runs on Android - so you could probably find an Android device cheaper than an iPad if cost is a concern…
    -james
    (a nomad. )
  • vjbelamy
    by vjbelamy » Tue Jun 30, 2015 6:17 pm
    non sono sicuro di aver capito la tua risposta. perchè saranno guai con modul8 versione 2.9?
